AFTER PROJECT NORTH SET CSV TOPO COMES IN THE WRONG PLACE
allanthebruce
Message 1 of 16
allanthebruce
Hi There,
When we create a different project north to True north and bring in a CSV (topo surface) it comes in the wrong area, this has us baffled? Should we create surface before we create a project north? I really didnt think it should make a difference?
Maybe there is something obvious I have missed....appreciate any input.
Allan
Replies (15)
Message 2 of 16
Could you explain what you mean you say the "CSV (topo surface) it comes in the wrong area"? Whether you in Project North or True North, the CSV file should place the points at exactly the same location.
...can you post the file and tell us the units?
Message 3 of 16
allanthebruce
Hi There  ,
Yes the units are meters, I've done this many times before but this time and when a Project north has been rotated I cant get the csv to place in the original location....
The CSV is a x,y,z file of points from Civil3d exported as a csv file.
Got me stumped.
If i import scv before project north has been rotated all is sweeet, but as soon as I say rotate it to alligned wall.....then no i cant get it in the same location.
appreciate your help.
thanks
Allan
Message 4 of 16
allanthebruce
HI Mate,
I have attached the csv and the 2 revit files one with a project rotation and the other without.
Allan
Message 5 of 16
Do you usually set Project North non-orthogonal to the view?
Reason I ask, is because it's unconventional. The CSV file works fine if Project North is Orthogonal to the view.
Message 6 of 16
@ToanDN, are you by any chance working on this one as well?
Message 7 of 16
@barthbradley No.  Why?
Message 8 of 16
Just messing with you.
Message 9 of 16
I know.
Message 10 of 16
allanthebruce
No this is merely a sample file to show that csv file comes in 2 locations, correct without a project north set and inncorrrect when rotated project north.....
seems crazy....
thanks
Allan
Message 11 of 16
If Project North is Orthogonal to the view, the CSV lands in the exact same spot, even if the view is set to True North. I just tested it 3 times; inserting the CSV onto a Site Plan oriented to Project North (orthogonal), and then oriented to True North (Angle to True North=323.66), and then oriented to Project North again.  All 3 topos are stacked on top of each other.
Message 12 of 16
allanthebruce
Thanks for that., any chance you can screen cast it?
Did you manage to get what was happening to me, by the way Revit 2017.
Appreciate your help.
Cheers
Allan
Message 13 of 16
Same here.  Topo is inserted to the same location WITHIN one file regardless of the view set to Project or True North.  Obviously they are different from one file to another but I don't think anyone need to question that.
Message 14 of 16
allanthebruce
Ok still cant get it....
see screencast.
Started new project. inserted csv, changed project north to align to wall, reinserted csv, lands in a different place........
am i silly or something is a miss.....
Message 15 of 16
Topos inserted BEFORE and AFTER you rotated Project North will land on different locations, as they should be.
Message 16 of 16
Viveka_CD
Hi @allanthebruce
Did the resolutions by @ToanDN and @barthbradley help resolve your issue?
Let us know if you have additional questions.
If so, please click on 'Accept as solution' to help others with similar questions.
Thank you,
