I am using Revit 2017 and I am trying to render in cloud, however I keep receiving the same error every time I try to send a rendering to the cloud. Based on other google searches for people with the same issues I have found that people said it can be due to Internet explorer, so as a solution I downloaded Chrome and made that my default browser and this still did not fix the issue. There was also information about having an apostrophe in the user name, which I do not have so I don't believe that is the issue either.
Are there other solutions to this issue? Attached is the screenshot of the error message I receive.
Hey
check this out I hope it can help :
I've actually experienced this same issue and it happens across the board in Revit 2016, 2017 and 2018. I've tried updating, reinstalling the program fresh as well as installing Revit 2018 to try and fix the issue. I had also read similar issues resulting from user account settings so I tried setting up a fresh autodesk account to "render in cloud" from which also did not fix the issue. The issue also persists despite which file I use, but renders just fine from a friends computer...
The funny thing about this is I was having no issue rendering in from the cloud at all, then Revit decided to give me this error in the middle of a session. Since then, probably a month ago, I have received the same error every time I try to render in cloud. PLEASE HELP FINAL REVIEWS ARE APPROACHING.
Hi @Anonymous,
I don't know if the problem still there?
Please upgrade your IE browser to newer than IE9 and try it again.
"https://forums.autodesk.com/t5/rendering-forum/help-cloud-render-error/td-p/7508895"
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
