adjusting MODEL patterns on a modified floor slab
yulia02801
yulia02801
When a floor is modified, and points set with ‘Z’ values, the patterns do not line up & When use the Align command Revit does not modify adjacent patterns to suit the desired direction, so how to adjust MODEL patterns on a modified floor slab
yulia02801
REVIT2021
azad.Nanva
@yulia02801 wrote:
REVIT2021
I don't have 2021 any more, but for this case i prefer to use Roof By Extrusion and Vertical Opening as the example:
azad.Nanva
and something more:
ramneetkaur86
@yulia02801 you need to select model pattern instead of drafting pattern in the selected hatch pattern to give you access to align individual lines and control the way the pattern is visible.
hope this helps 🙂
handjonathan
Hi @yulia02801
Thanks a lot for posting your question to the forums!   Has the solution suggested by @azad.Nanva @ramneetkaur86 helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
