Adjusting a roller shade family
ray
Message 1 of 8
ray
Hi
I'm having a hard time figuring out how to adjust this roller shade family.  When placed it attaches incorrectly to the ceiling.  The same issue is present with ceilings or the underside of a floor.
What part would I edit so that it attaches within the ceiling instead of on the surface of it?
Family:
Replies (7)
Message 2 of 8
Seems to host to Ceiling or Floor just fine.  Top and bottom face.
Are you selecting "Place on Face" or "Place on Workplane"?
Message 3 of 8
You could even place it on a Named Ref. Plane. That's a Work Plane.
Message 4 of 8
I would host it under a soffit above the ceiling, like how it should be done in field.
Or place it on a ref plane above the ceiling if you don't feel like modeling the soffit.
Message 5 of 8
Flip Work Plane doesn't work on a compound ceiling or floor with this family.
Message 6 of 8
ray
Thanks for the replies!  I'm not really looking to flip the component, it needs to be set high up into the ceiling, like this:
Is there an edit I can do to the family itself? Or do I need to create little soffits as suggested, or perhaps look into other solutions like making a whole new family?
Message 7 of 8
mhiserZFHXS
You could edit the family, but making the soffits would probably be easier if this is a one time thing.
Message 8 of 8
ray
I ended up making a nested face based family with it's own ceiling soffit of sorts.  The "upside down" thing still throws me off, but it works.
Family
Placed in model:
