Delete linetype using Dynamo (Python 3)
anthony_iskandar
anthony_iskandar
It was working several months ago, I think it's because the Python 2 is changed to Python 3, and I don't know how to solve this.
Please help.
vancikv
The error message is pretty clear. Your input is a bunch of strings that naturally have no Ids in your Revit document. The script is not aware of the fact that they're actually names of line styles. You're saying "give me the Ids of these strings", but you actually need to say "give me the Ids of line styles that are named according to these strings". I don't see how this could have ever worked. Didn't you change the input from the last time?
vancikv
To offer a solution: Try connecting the input of the "Element.Name" node directly in your script.
stefan_gokstorp
there is a node from modelical that does exactly this.
if you are hellbent on having your own code check how its done in that package.
but i would just use that one
