Good morning,
Is it possible to adjust the text for different views? I would like to have this text smaller. When I change this, the text is changed in the entire project. I don't want that because the text is really small.
Thank you !!
Solved by benschilders. Go to Solution.
Yes this is possible.
1. Click on duplicate
2. Change name to something logical like the text height you are gonna use
3. click ok
4. Change settings according to your needs
5. Click ok to save the new type
6. Use the new type wherever you like
No problem, now you know the principle of types 🙂 .
