Cant locate my model in 3D view - model is just topography
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
AidanHawkins
630 Aufrufe, 7 Antworten
Hi there
Can someone take a look at this file attached
Every time I go into 3d view I can not see anything..
I don't know what is going on
Aidan.
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: AidanHawkins
View phasing?
Nachricht 3 von 8
benschilders
If i really can't find a element i try to check off this list until i find the object.
  1. The object or category is temporarily hidden
    2. The object or category is hidden in the view
    3. The object is being obscured by another element
    4. The object's category or subcategory is hidden in the view
    5. The object is outside the view's view range
    6. The view's far clip depth is not sufficient to show the object
    7. The object resides on a work set that is not loaded within the project
    8. The object resides on a work set that is not visible in the view
    9. The object resides on a work set that is not loaded in a linked file
    10. The object resides on a work set that is not visible in a linked file
    11. The object resides within a group (detail model) and it has been excluded from the group
    12. The object is part of a design option that is not visible in the view
    13. The object is part of a linked file that is not visible in the view
    14. The object has one or more of its edges overridden to display as '<Invisible lines>'
    15. The object is a family and none of its geometry is set to be visible in the view type
    16. The object is a family and none of its geometry is set to be visible at the view's detail level
    17. The object is set to not be visible at the category's detail level
    18. The element has been placed outside the view's crop region (visible extents)
    19. The element is an annotation object and does not reside entirely within the annotation crop region
    20. The object's phase settings or the view's phase settings prevent the object from displaying in the view
    21. The view's discipline is prohibiting the visibility of the object
    22. The object is affected by a filter applied to the view
    23. The object is subject to an element override, set to color
    24. The object is subject to a category override, set to color
    25. The object style is set to color
    26. The object is constrained to a scope boxes that is not visible in the view
    27. The extents of the object itself don't permit it to be seen
    28. The object is a mass, and 'Show Mass' is turned off
    29. The object's host view has been deleted (area boundaries)
    30. The view's scale is prohibiting the object's visibility
    31. The object is a linked instance with coordinates too great for Revit to handle
    32. The user has incorrectly identified the link instance to which the element belongs
    33. The object is in a link that is not in its correct position
    34The object is really far away from 0,0,0, (zoom all to check)
Source:
https://forums.autodesk.com/t5/revit-architecture-forum/unble-to-see-selected-doors-and-objects-in-l...
pyRevitHave a look at my idea: Material priority Revit quick start guide ┃Please accept soulution if my anwser solved your problem
Nachricht 4 von 8
AidanHawkins
als Antwort auf: ToanDN
I tried this but no luck
Everything is in new construction and show all
Nachricht 5 von 8
Is this what you are looking for?
....I can't find anything else in the Project. I didn't check beyond Earth though.  Maybe it's on another Planet?  :zwinkerndes_Gesicht:
Nachricht 6 von 8
There are 3 CAD links.  You don't see them in the 3D view because they are too far away from Project Base Point/Survey Point/Internal Origin.
I would insert them center to center then acquired coordinates instead of Origin to Origin.
Nachricht 7 von 8
Ah! I found your 22 0726 Site.dwg.  It wasn't on another Planet after all. :zwinkerndes_Gesicht:
To get it to show up in Site Plan,  uncheck all the other DWG imports under the Site Plan View's VGOs, and then change your Site Plan View's View Range Top, Bottom and View Depth Level to "Unlimited"
Nachricht 8 von 8
AidanHawkins
als Antwort auf: barthbradley
Thanks I have done so
But it still doesn't work for me
I want to see my project in 3D View
