Adding "Grips"
Adding "Grips"
DrakeCanyonArchitecture
Adding "Grips"
I'm only 2 days into Revit and have a really simple question but am unsure of the terminology so I'm not sure what to search to find the answer. I would like to add a "grip" or "vertex" so that I can drag the datum out of the way so the one above it can be read.
Kevin Mendenhall
Revit Architecture 2022
Microsoft Windows 11 Professional
Dell Precision 5870 - x64 based PC - Intel Xeon CPU @ 3.80GHz, 6 Core. 80Gb RAM
Installed Add Ins - Enscape/StrucSoft MWF/LotSpec
Alan.johnson1970
Select the level line and you will see a little squiggle
Select the little squiggle and then you will see the blue grips
Adjust (drag) as required.
AJ.
I knew it had to be really simple. I tried everything, right clicking, alt+click, ctrl+click, and searched every term I could think of. It's so simple that it's hard to find anything on it. Thank you so much!
Kevin Mendenhall
Alan.johnson1970
No worries, happy to help.
AJ.
loboarch
I know you already got your answer, but just a search in Help for "level" revealed the answer pretty quickly with a little scanning of the Table of Contents.
http://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-73305787-6155-4615-851C-85394CB459AD
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Sure enough, it's even animated. I should rely on the help files more. I tend to Google a lot because the various answers seem to be more in depth on YouTube, forums, etc, and help usually shows up in the search results as well. I just wasn't sure what to search for. Thank you for directing my attention to the help files.
Kevin Mendenhall
