Adding materials/finishes to Walls
tstewart
tstewart
How to add finishes (i.e., metal panels, siding, stone, etc.) to walls' surfaces?
Look under the stock Assets that comes with Revit.  There is one using a similar Image. You can assign it to a Material to be used by your Wall Finish.
...you can also use these Images in Revit in your Material's Appearance Asset.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2021/EN...
tstewart
Where are the Stock Assets in Revit and how would I add the attached photos to the Materials library?
Did you happen to see the Link I provided above?
...not sure where you are getting stuck. Are you unclear about how to  navigate to the Asset Browser, or how to insert or change an Image?
