Adding material to toposurface
I have tried everything to visualize the Grass material in the toposurface. It is seen when I render it. But how can I visualize it while being in 3D View with Realistic or Consistent Colours for example?
Here's the file, it's just the toposurface
Isabel
Accepted solutions (3)
dzanta
I looked at the file...
you have two topo surfaces on top of each other.  i deleted one of them and the other looks like green grass.  See image.a.jpg
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
RDAOU
Go to Manage >> Object Style >> Model Category >> scroll down to Toposurface
Set it to Grass... You have it set to Earth ... And delete the duplicate Toposurface (Not sure why 2)
Thanks. I didn't know I had a duplicate. Where can I see that? haha
RDAOU
@Anonymous
See screencast...If you select using a crossing window you will find two toposurface.
If you tab select the first you notice it is set to material grass.
If you tab select the second you notice it is set to material by Category (this receives the material defined in the Object Styles section for Topo)
Thanks!!! By the way, I have installed several times screencast but when I sign in, it just doesn't work.
