“ghosting”
“ghosting”
Message 1 of 23
“ghosting”
We are having issues with “ghosting” walls duplicating in the existing drawings because walls that were created in the existing phase, and then demoed in existing phase. How do we find these ghosted walls?
John Martinez,
Replies (22)
Message 2 of 23
Sahay_R
Have you looked at your Filters? We have a filter applied to our demo plans that dashes out demo'ed walls like this. You may have one that needs to be turned off.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 23
PijPiwo
Also, try to set your floor plan view (either existing or new construction phase) phase filter to none or show all. The demolished walls should show.
Message 4 of 23
The problem is that those walls were created and deleted in the same/wrong phase phase, so the walls are physicaly gone however the "ghost" does not allow new construction walls to be joined.
Message 5 of 23
Sahay_R
Have you taken a look at what shows up when you set the phase to None?
Rina Sahay
Message 6 of 23
PijPiwo
Deleted or demolished? it's a huge difference. Can you post a pic of the problem?
Message 7 of 23
The "ghost" still exists however the walls are gone.
Message 8 of 23
Yes I tried setting to none, nothing shows up.
Message 9 of 23
Both, deleted and demolished, it was demolished in one phase and deleted in a different phase, so I can not join walls in that spot now.
Message 10 of 23
Sahay_R
Just a thought. Have you tried to delete a wall that the ghosted wall was connecting to?
Secondly - do the ghosted lines print? If they don't then that may be the way to go.
Rina Sahay
Message 11 of 23
the demolished walls were deleted in the wrong phase so the walls can not join in that spot.
Message 12 of 23
Sahay_R
No - what I meant was to try to erase a wall that a ghosted was connects to. Maybe that will solve the problem.
Rina Sahay
Message 13 of 23
Create a wall schedule of existing phase, phase filter set to show
Temporary only (you need to create this filter under Phase settings). See
if anything appear in the schedule.
Message 14 of 23
it joins to another ghosted wall
Message 15 of 23
 This sounds promising...Do i create the temp phase in the model under Manage or in the schedule?
Message 16 of 23
You don't have to create a new Phase, only a new Phase Filter under Manage/Phases.  See below for Phase Filter and schedule view settings.
The reason being is an object created and demolished under the same phase is classified as Temporary.
Message 17 of 23
PijPiwo
Toan, correct me if I’m wrong, but shouldn’t phase filter set to ‘none’ display everything. ‘None’ means no filter applied, so either demolished or not, existing or new, the elements should show if they exist in the model. Is ‘temporary’ filter going to reveal anything new, other than 'none' can show?
Message 18 of 23
You are absolutely NOT wrong.
But this case appears to be abnormal so I just proposed an unconventional method. I can't guarantee it will work, but it does not hurt to try.
Message 19 of 23
PijPiwo
Got it 🙂
Message 20 of 23
Thanks for your reply, I have a deadline on Monday and I won't be able to try it until after that. I willl let you know.
Thanks again!
