adding grass and background
hi,
im currently working on a house drawing, part of the build is below ground level -2600 how would i go about drawing this on and showing grass in background aswell
so basically you drive down to the house at 1st floor level, then it goes down to ground level around the house if that makes sense
cheers
d.avalishvili
i guess better way is to make landscape first 🙂
otherwise u can use region tool and  draw grass (using hatch patterns) wherever u want.
Ilic.Andrej
A common practice is to create a topography and then building pads.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
