Adding elevation views to different drawings/views?
cjacobsLDX59
Message 1 of 17
cjacobsLDX59
Hi all,
So I have a project with two structural plans in it. In one plan, I can add elevation views just fine, and yet in the other Revit won't let me (see below screenshot, NOTING THAT I'VE BEEN LOOKING INTO WAYS TO FIX THIS WITH VISIBILITY PARAMETERS, UNSUCCESSFULLY, FOR CLOSE TO 24H AT THIS POINT). Does anyone know what specifically might be preventing me preventing me from adding elevation views to this other structural plan?
Thanks in advance,
Replies (16)
Message 2 of 17
RSomppi
I think the list in the message is somewhat specific. Without the model, it's hard to get any more definitive.
Share the model.
Message 3 of 17
syman2000
Check and see if the elevation category is turn on.
If it is, check and see if the elevation is also set to large scale.
Message 4 of 17
cjacobsLDX59
It's a model I'm working in for my job, so unfortunately I can't share it.
Message 5 of 17
cjacobsLDX59
Already confirmed each of these multiple times, unfortunately.
Message 6 of 17
RSomppi
You've got the information that you need. You have a working view. What are the differences?
Alternatively, just create a new view using a view template created from the working view.
Message 7 of 17
syman2000
Check and see elevation set to what discipline and hidden set to none.
Message 8 of 17
cjacobsLDX59
Tried just now - no luck.
Message 9 of 17
cjacobsLDX59
The differences is what I'm having a hard time determining, as they seem to have identical settings across the board.
I can't just make a new view, as I'd lose the days' worth of work I've put into my problem view.
Message 10 of 17
Did you ask the same exact question in at least one other thread?  Set the elevation views' Discipline to Coordination.
Message 11 of 17
RSomppi
You won't lose anything if you don't delete the problem view. Annotations can be copy/pasted.
Message 12 of 17
cjacobsLDX59
I've been asking very similar, related questions because this problem has had me stuck at work for an entire day at this point.
I've already tried changing its discipline with no luck.
Message 13 of 17
Please show the properties of the elevation view and the structural plan view in two separate pictures.
Message 14 of 17
cjacobsLDX59
Structure:
Elevation:
Message 15 of 17
Edit: @syman2000 is correct.  Your elevation only shows in full scaled (12" = 1') plan view.  You need to change the [Hide at scale coarser than] value to something smaller than the scale of your plan views (1/8"=1' as you show it).
Thanks but I need to see the full properties panel of the views, not the views drawing area.
Message 16 of 17
syman2000
Your scale is set to 12" = 1'-0". Change it to 1" = 400'-0"
Message 17 of 17
RSomppi
That would be coarser.
