adding a column on sheet issues/revision in revit
Message 1 of 25
Hi Everyone,
Just wanted to ask if it is possible to add column/s on sheet issues/revision in revit?
gerald
Replies (24)
Message 2 of 25
Sure it is. Just add parameter fields to the "schedule".
...what are you wanting to add?
Message 3 of 25
saman.nejad
Looking to do the same. Have you found a solution?
Message 4 of 25
Total how many columns do you need?
Message 5 of 25
saman.nejad
9 columns to be exact. Rev., Emission Type(E.T.), Description, Designer, Drafter, Ver., Apr., Aut. and Date.
Message 6 of 25
Is Emission Type value per project or per sheet?  If per project then you can add a Project information parameter to the schedule.  Plus, enter Designer/Drafter/Ver into a single field such as Issued By.  Apr. = Issued to.  Not sure what Aut. is but you can use Project information > Author.  There you go.
Message 7 of 25
saman.nejad
The Emission Type, Aut. (Autorized By) values is per project but the Rev., date, ... are per sheet values.
Thanks for your help.
Message 8 of 25
Then what shown above should work perfectly fine..
Message 9 of 25
akshaprojects
Create a new field is unavailable. Edit(or delete) an existing one is greyed out. What do I need to do?
Message 10 of 25
What information do you need to show in the new column?
Message 11 of 25
akshaprojects
@ToanDN
I need a column for 'Checked by'. I know there is no existing field in revision schedule for that but if I want this added, how do I do it? I wouldn't mind renaming 'Issued to' field to 'Checked by' if at all it was possible.
Message 12 of 25
@ToanDN
Seems redundant.  Don't you have Checked By as  Sheet's parameter already?
Message 13 of 25
akshaprojects
@ToanDN
First of all, my initial query was that I am unable to add new parameters to Revit's in-built Revision Schedule. Is there a way to do this? I created a shared (type) parameter 'Checked by' in the sheet but it does not appear as one of the available parameters in the revision schedule.
Message 14 of 25
@ToanDN
I know what you initial query is and I know user's parameters cannot be added to revision schedules for the time being.  My question for you was why do you need to add [Checked By] to your revision schedule when the built-in [Checked By] parameter already exists and can be shown on the sheet's titleblock?
Message 15 of 25
akshaprojects
@ToanDN
Now I understand your previous query. So, the 'Checked by' parameter from sheet is used as Engineering check in our office and it exists on our title block. The checked by on the revision schedule is for drafting check and is checked by different person each revision.
What I have done for time being is to create a 'calculated' field named 'Chkr' and equalled it to existing 'isued by' field.
Message 16 of 25
@ToanDN
I thought you said you had no fields available.  If [Issued By] is not being used then why don't you just use it and rename the Schedule Header to Chkr instead of adding a Calculated parameter, which will show the exact same value?
Message 17 of 25
ramakrishnan.n
But is it not stupid from auto desk part in not providing to add fields for revision column , i ve drawn by , designed by , apprd by col in addition to issue by and issued to columns. how to insert all this , autodesk support to answer
Message 18 of 25
Edit your titleblock family, edit the revision schedule, add fields to it.
Message 19 of 25
ramakrishnan.n
but in revision schedule there is no provision to add extra field .. the filed should be sheet wise parameter not project wise.
Message 20 of 25
ramakrishnan.n
can you please show how to add extra fields in revision schedule im using revit 2022
