I want to add a View title parameter to edit the label of a View Reference family. Currently the ability to add or create parameters for View Reference families is greyed out. I basically just want to be able to reference a View's name, rather than its sheet number. Is there another way of achieving the same thing?
The View Reference family is pretty locked-down. There are few edits you can make to it, and you can't add parameters to it.
There is an Idea requesting more ability to edit parameters in View Reference families at this link:
Yeah, I get what you are saying now -- and I'm trying to imagine how that would work. A View Name among several hundred sheets?
Make a new Tag for View Ref. then change Family Category to View Titles, Create a Label called Sheet Number copy the sheet Number label, Change your Family Category back to View Ref., Paste the sheet number Label, and Load into your project. Now open the View Tab, select View Ref.
, Edit Type, select the drop down box Under Graphics you will see View Ref. Tag find your New View ref.- Close out and place a View Ref. Pick the Sheet you want to Reference. DONE.
If this isn't clear pleas drop a note and I will try to elaborate.
Amazing! Works for Sheet Name but not for View Name, so things are a little bit better.
