add phase to annotations
Message 1 of 47
Hi, how can I add phase to annotations. I should prepare existing and new construction drawing and just don't know what to do with annotations.
Replies (46)
Message 41 of 47
loboarch
@cbcarch wrote:
FWIW--after almost 20 YEARS, I finally got my Tilt Wall Tool!
Good things are worth waiting for...………...😉
Slanted Walls came out last year, and Autodesk has not even been developing Revit for 20yrs yet. (In the 19th year under Autodesk management now.  🙂 )
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 42 of 47
cbcarch
Yup---
That's why I wrote : "after almost 20 YEARS"...……………...
But I began using Revit in the Charles River Technology days, BA ( Before Autodesk) Period.😎
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 43 of 47
loboarch
I am a Revit "old timer" too.
Jeff Hanson
Revit Help |
Message 44 of 47
cindy.parvez
This needs to be on Autodesk radar.  Phases are comingled in the real world.  Furniture/fixtures/equipment is relocated or stays in place during a renovation and the associated MEP work needs to tie into existing which needs to be denoted as such. Making lots of views is not the answer.
Message 45 of 47
RobDraw
There's more than one way to skin that cat. If you're stuck on something that requires new functionality then you are in the wrong place. Try the IDEAS forum.
Rob
Message 46 of 47
TudorBeachApt
With that kind of attitude there would never be any progress.  We would still be lighting fire by rubbing sticks.  Poor old Mother of Invention would have Noting to do.
Message 47 of 47
RobDraw
So, instead of coming up with solutions that work now, you would rather wait for a questionable feature to be added to the program? You call that inventive? That sounds an awful lot like you are contradicting yourself.
Rob
