Hi fellas!
Does anyone know a good way to batch add shared parameters?
Adding each parameter one by one is tiresome for larger projects with many files, usually done for sheets and their parameters.
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Thank you, @barthbradley RF tools is a great add-in I've used personally for projects. See demo below:
@Marcus.Isacsson HERE is another post with batch add-in recommendations by @Alaaeldin_Alsahli
If you find posts have solved your problem, please click on 'Accept as solution' button below to help others with similar questions.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
