Adaptive Family Turns Upside Down
13 REPLIES 13
Message 1 of 14
simay.harmancioglu
698 Views, 13 Replies
I have created an adaptive family which will function as retaining wall. All the parameters work perfectly fine, except the spline path (reference line) passing through the adaptive points I guess. In the screencast below you can see that it works fine when it is concave, but when I try to make it convex it turns upside down. Has anyone had this problem before?
Screencast link:
Tags (3)
Labels (1)
13 REPLIES 13
Message 2 of 14
in reply to: simay.harmancioglu
Set adaptive points to Instance XY global Z, or set the family to Always Vertical.
Message 3 of 14
simay.harmancioglu
in reply to: ToanDN
Actually it's already set to Always Vertical and the points are set to Placement Points and Global Z then Host XY.
Message 4 of 14
Aren't you inside the AP Family in that screencast?  AP Orientation setting inside the Family doesn't affect anything.  If you want to test Orientation, load and place the AP Family on a Host in another Project.
Message 5 of 14
Even when I load it into a Project environment I cannot have the geometry I want. The middle AP won't go any further like in the link below.
https://knowledge.autodesk.com/community/screencast/f0fe1292-7115-4d64-949a-5189b117cd81
Message 6 of 14
Post the Family.  We'll figure it out for you.
Message 7 of 14
Set the form to have Consistent Profile.
Message 8 of 14
It's a bit messy but here you go.
Message 9 of 14
Try this one.  This is just an example for you to reverse engineer.  The profile is not the same as yours.
Message 10 of 14
simay.harmancioglu
in reply to: ToanDN
Thank you, this one works but I need to divide the profile vertically and horizontally cause I'm assigning Visibility parameters for each of them. I tried to load my profile into your family. But then I couldn't generate a solid with it for some reason :(, maybe because I have intersecting lines in my profile. But as I said, to be able to set the Visibility parameters I cannot have one single profile I suppose. What is your suggestion?
Message 11 of 14
Create each profile as a family, load them in host on the same ref point, then create a form from each profile.
Message 12 of 14
simay.harmancioglu
in reply to: ToanDN
Now when I lock the second profile it turns 90 degrees and lays on the plane. How can I solve this?
https://knowledge.autodesk.com/community/screencast/3fed78de-150f-4cde-8ff7-e1db46ba101a
Message 13 of 14
Before digging into this.  Any reason you opted to use an adaptive family instead of a more conventional approach such as a sweep, a swept blend, or railing?
Message 14 of 14
simay.harmancioglu
in reply to: ToanDN
I need adaptive points to control the spline.
Forma Design Contest
