Adaptive family - perpendicular to curve
andre.micka
Message 1 of 10
andre.micka
I am trying to create an adaptive family from imported points with Dynamo.
I create reference points and reference line with dynamo.
After, I divide the line and attach a profile (another adaptive component) to repeat on the curve.
When I send this family in the project, I verify the coordinates and I have found that the repeated adaptive component is not really perpendicular to the curve. Look at the red lines which are the real surface of the element (from autocad)
Is there a way to have a real perpendicular adaptive component ?
Thank you
Replies (9)
Message 2 of 10
andre.micka
With the files it is better !
Message 3 of 10
andre.micka
No one here ?
Message 4 of 10
FAIR59
A.f.a.i.k. there is no automated way to orient a family to the vertical and perpendicular to a line. You have to define the vertical yourself. Fortunately that is relatively easy with your problem. Make a 2nd identical divided path with a vertical offset.
  • Set the adaptive points to [ Global (z) then Host (xy) ] this defines the vertical.
  • Set the workplane to the horizontal plane of the first adaptive point, and place a reference point onto the adaptive point, giving it an offset.
  • repeat for the shape handle points and the other adaptive point.
  • select all the reference points and make a spline
  • make a divided path from the spline, with the same number of points as the original one.
Make a 2 point adaptive family with the adaptive points set to Orient to [ Host (xyz) ]. Place a reference line between the adaptive points, place a point on the line and host your section profile to the correct plane of the point.
  • place the 2-point adaptive family on a point of the divided path and on the point above of the 2nd divided path. The reference line in the 2-point adaptive family between the adaptive points is now vertical and perpendicular to the divided path.
  • repeat and create form
Message 5 of 10
andre.micka
Thank you for your help.
The problem is not with the Z axis, it is in the XY plan view.
The profile are not perpendicular to the curve.
Maybe I was not enough accurate.
Thank
Message 6 of 10
andre.micka
Thank you @FAIR59 ,
I red again your response and it is exactly what I need.
 But... I don't find the way to achieve what you have done...
Some steps are not familiar to me. I never used adaptive family before.
Is it possible to you to make a screecast to show me step by step with a simple rectangle please ?
Is this part must be manual ? ==>
Than you very much for you help
Message 7 of 10
FAIR59
Some pictures to clarify things:
ReferencePoint onto another Point:
  • set workplane to horizontal plane of (adaptive ) point
  • place point onto (adaptive) point
  • select point and define offset
This process can be automated
ReferencePoint hostpoint; // AdaptivePoint or ShapehandlePoint
XYZ offset = XYZ.BasisZ.Multiply(3);
XYZ newlocation = hostpoint.Position + offset;
PointOnPlane planeref = PointOnPlane.NewPointOnPlane(doc,hostpoint.GetCoordinatePlaneReferenceXY(),newlocation,XYZ.BasisX);
ReferencePoint newPoint = doc.FamilyCreate.NewReferencePoint(planeref);
2-Point family for section-shape:
  • host point onto reference line between the 2 adaptive points:
  • set workplane to a plane of the point
  • sketch profile
  • select point and move point to final position, by giving the [ Normalized Curve Parameter ] the value 0.
Message 8 of 10
andre.micka
Thank you very much, that works great !
Just a last question the automatisation of your last post,  how do you use it ? In dynamo ?
Thanks again
Message 9 of 10
FAIR59
The code are the basic "calls" you'd have to make , when writing a macro or add-in. And also a dynamo node (if any exists) will use the same calls behide the scenes.
Message 10 of 10
andre.micka
I have another question to complete this tread.
I tried to had anoter adaptive point to the section shape family.
This 3rd point is here to set the slope and the width of this rectangle.
I have now 3 path. 2 for the verticality and the 3rd for the width and slope.
paths.pngI can't make it, the geometry is either deleted by revit or the geometry of the rectangle is not conserved.
Is it possible to make this ?
