adaptative linear light
TomasoCardia
TomasoCardia
Hi all..
I'm tryin' to build a linear light, which is insert on a "U" profile. Actually the lights on this profile are put every 120cm.
So I did the single lamp (45 cm) with an adaptative model, then I insert it inside other ataptative model with the U profile (after divide the line in segments of 120 cm).
the profile seem works! but in the and of the segment appear a lamp. why? How can I avoid it? thank you!
Share the families for a better understanding.
TomasoCardia
this is the model (Revit 2016)
You need to make the divided path 1200 mm shorter than the channel.
TomasoCardia
Is there a way to obtain that the object is always horizontal or always vertical?
When I insert the light inside the model it is never horizontal or vertical..
