Access element in a loaded family
aclarke
aclarke
EDIT:
I just realized this is posted in the wrong section "Trouble Shooting".  I am not sure how to move this to the correct forum section 'General' other than re-post.
Hi all,
How can enter a loaded family and access elements in this loaded family?  Specifically a filled region that is placed in a Title Block, I want to return this filled region's bounding box.
I have tried 'GetSubComponentIds()' and 'GetSubelements()' but both return '0'.
Any guidance would be greatly appreciated.
AlanC.
hmunsell
are you trying to use Dynamo? Dynamo has there own Forum.
https://forum.dynamobim.com/
Howard Munsell
aclarke
no, I am using C#
the snip-it you show, I can see the confusion, my mistake.
what I am doing is returning a count of sub elements, just to see if I can access them, here is the code I used
TD() is shortcut function for TaskDialog.Show("task", e.GetSubelements().Count.ToString());
When I select my title border with the code below, the result is '0' but  this border is full of stuff.
Reading this, https://thebuildingcoder.typepad.com/blog/2010/02/nested-family-instance.html
Maybe I need to use 'GetSubComponentIds()' and 'SuperComponent' but I still got '0' when replacing 'GetSubelements' with 'GetSubComponentIds().  I am assuming that SuperComponent is the parent family, the definition is not clear.
ISelectionFilter filter = new myFunctions.mySelectionFilter();
            Reference reference = uidoc.Selection.PickObject(ObjectType.Element, filter);
            FamilyInstance e = (FamilyInstance)doc.GetElement(reference);
            TD(e.GetSubelements().Count.ToString());
hmunsell
LOL... Oh, i'm not a Coder. but maybe someone else on here can make sense of it :-). i'm still trying to learn Dynamo.....
Howard Munsell
aclarke
lol...
So I assume I posted in the Revit Trouble shooting forum...  I will repost, in the proper place.
PavelAnd
It would be better, if you ask your question here.
Best regards, Pavel Plotitsyn.
aclarke
