Acad linked file imports. getting text to scale correctly
vanderloo5
vanderloo5
What needs to happen to get the leader text in an Acad file to import, (via link cad), and display as it does in the .dwg file in autocad? The top image is a screenshot from the Acad file, The bottom shows how it's coming into Revit.
syman2000
Unfortunately Revit cannot read AutoCAD MTEXT override. The only way to fix this is to run lisp routine inside AutoCAD to strip away any MTEXT override format. Once you do that, Revit will pickup the AutoCAD text properly.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/strip-mtext-formatting/td-p/12085133
