About setting maximum rebar length for the beam
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
4406 Aufrufe, 4 Antworten
If I work on a huge site like this, I have to face with a situation that I do need a lot of long long rebars.
Especially the walls and beams
So here comes my question
(In Korea Maximum bar production length is 8m)
When I do the rebars It just focus on the beam I'm working on with the green box, right?
But in reality (in Korea I mean) at least 4 rebars in the beam start from the wall and it goes until the 8m rebar ends then lap splicing
There is a rebar program that I can set the rebars in the beam (like we can edit the beam size, we can set the rebars in the beam)
So if I place the beams, the program automatically calculate every 8m and do the lap splicing
I just want to know If there is any funtion like that in Revit
My boss used to use that program and now he wants to use Revit for the rebars too because it's better
But I don't think Revit is better about this
When I do the rebars in Revit I feel like a caveman
I have to draw every rebars in the beams
I've been watching many youtube videos about reinforcement but so far I got nothing
I may see the add-in program something like that but I'm not sure
Earlier I asked about how I can set the meximim rebar length
The answers I've got they are about fabric sheet (thanks for the hints by the way)
I really need to know If there is better easier and smarter way to do it instead of drawing every bars?
Thank you guys
4 ANTWORTEN 4
Nachricht 2 von 5
aleksei.tkachenko
als Antwort auf: Anonymous
Hello
When I work with large beams or slabs, I draw only one long rebar and use schedule to calculate length and number as if this rebar would consist of few smaller rebar.s It makes the model easier  to handle and reduces time required for modelling. But you have to make some improvement in rebar schedule. I attached a video that explanes what I mean.
  1. Create following parameters in rebar schedule
  • Cut on Site – Instance – General – Yes/No
  • Lap Splice Multiplicator – Type  General  Number
  • Stock Length  Type  General – Length
  1. Create calculated values «Rebar Length». Use following formula:
if(Cut on Site, Stock Length, Bar Length)
  1. Create calculated values «Quantity’». Use following formula:
if(Cut on Site, Bar Length * Quantity * Lap Splice Multiplicator / Stock Length, Quantity)
  1. Make fields Bar length and quantity as «hidden»
Hope it will help
Nachricht 3 von 5
als Antwort auf: aleksei.tkachenko
Hi Aleksei
You art just one step away to be my hero!
Thank you so much for the replying.
I have one more favor to ask.
The size of the video you uploaded is too small on the autodesk community page.
I can't see exactly what you are doing.
So, can you send me the video to me?
My E-mail address is shandia31@naver.com
Thank you!
Nachricht 4 von 5
You need to click on the maximize button on the bottom right of the video to view it full screen.
Nachricht 5 von 5
giouvele
Thanks a lot for sharing! Any other 'tricks'  with formulas? Where i can find them?
