Material Properties (Transparency)
5 ANTWORTEN 5
Nachricht 1 von 6
2118 Aufrufe, 5 Antworten
I have a problem.I'd like to make a grid on curtain wall panels and than I create a material with the surface pattern "Grid" and 100% Transparency. The problem is when I make Elevation views sometimes it works well but sometimes it doesn't. The same difficulty appears when I print my sheets in pdf. It will be very helpfull to find the solution.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
I think your view visual style is different in these two files. Try to put both on Shaded not Hidden Line.
If you find my post is interesting, I will Appreciate it if you give a Kudo.
If it solves your problem, please click Accept Solution.
Nachricht 3 von 6
filipeoconde
Hi @Anonymous, how did you manage to make the surface pattern transparent?
Mine is neither on Shaded nor on Hidden Line, I know how to make a Pattern Fill transparent/opaque, but couldn't figure out how to do it to a Material Surface Pattern...
Nachricht 4 von 6
als Antwort auf: filipeoconde
Nachricht 5 von 6
Hi @filipeoconde
@ToanDN has answered your question :leicht_lächelndes_Gesicht:
Nachricht 6 von 6
filipeoconde
als Antwort auf: ToanDN
Hi @ToanDN, @Anonymous, thank you for the response (especially for the readiness of it!). I didn't even thought of working with shading transparency...
