A360 Team Model Viewer Assembly not loading all links
amorris3817
amorris3817
It seems when uploading Revit files as an assembly to A360 Team, (not using C4R) Nested Files are not appearing. For example, the Architectural Shell model is not loading. The interior model is loading as a link but the Architectural shell model that is nested / linked into the interior model is not loading
All non-parent links are set to attachment.
Architectural Shell model is Linked to
Architectural Interior Model is Linked to
Electrical Model (Parent Model)
Hope that makes sense.
PrathapSekar
Hi @amorris3817,
             Try, loading your nested family as Shared family by checking the 'Shared' check box in properties pallet (Image attached).        Shared Family.png
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
amorris3817
Thanks for the response, however, The issue a hand has nothing to do with families. When I speak of nested I am talking about nested .rvt "LINKS" not nested families.
yurikim
Thank you for your posting @amorris3817
If we use C4R to publish the project, linked files should come along, but it seems you haven't uploaded via C4R. If this is uploading directly to A360, you will have to upload the entire project including all linked files.
Please let me know if you have any more questions.
Yuri Kim
Product Support Specialist, AEC
