A360 project loading fail. "FAILED TO REGENERATE..."
steve
steve
Epic fail trying to load a BIM360:  this helpful disaster message displays.   I opened normally, from the BIM 360 blue icon, navigating to the BIM360 folder location where the .rvt file is located and get this message... https://drive.google.com/a/designbuildllc.com/file/d/1kCHo-wwPQwpWI7JutjzW2rQOdP-eU9Uc/view?usp=driv...
translation ... "we thought we'd throw your project in the trash"
I have tried opening with an audit.  no go.    The model displays on the  Bim360 document management page, a publish from 2 days ago.   https://drive.google.com/a/designbuildllc.com/file/d/13UlJ-SLQ6Fz-le7FtAv17tNJLmFFCe_c/view?usp=driv...
Assuming the good folks at Autodesk have indeed shredded my work, where are the backup copies stored in A360?  How can I "revert to a previous of the project"  as the Revit dog that ate my homework advises?
Other bim360 r2019.2 projects open fine.
KrisAribal
May this article from the knowledge center help you:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
let's hope that the model is not corrupted
Kelsey.S
Autodesk Support
Autodesk Support
Hi @steve
I may be late here but are you able to open the file with an audit? Or did you already move to a "working" copy?
This link may have useful info: Recovery options for Revit cloud workshared models stored on BIM 360
Please mark any posts that help with "Accept as Solution" and thanks.
Kelsey Skaug
Autodesk Technical Support
Kelsey.S
Autodesk Support
Autodesk Support
Hi @steve,
I am following up to see if you got your questioned answered?
Please let us know.
Kelsey Skaug
