A360 Causing Revit to Crash
broderickwhitlock
broderickwhitlock
I know that A360 was retired back in June of last year (2018).  If its still installed on a computer, and that computer is trying to sync with BIM360, would that or should that cause Revit to freeze and crash?  See attached image.
Has anyone had experience with this, and does the removal of A360 mitigate the freezing issue?
RobDraw
Since you don't need it, why don't you try uninstalling it to see if it improves things?
Rob
broderickwhitlock
Yep, thats the plan! Just seeing if anyone else has had this issue, uninstalled with no recurrence.
broderickwhitlock
@RobDraw It was a firewall proxy issue, that was blocking Revit from syncing with BIM360.
