a software problem has caused revit 2018 to close unexpectedly
ModernArchWorld
ModernArchWorld
Hello Can someone tell me how to fix that my Revit 2018 unexpectedly closed during working on project. Why? Thank you
nmarcelis
I would recommed you to make it a habbit to regulary save your project. Ctrl+ s is your friend.
If you incounter this crash Often audit your revit project before opening it
If this helps you accept this as a solution
Revit Certified Professional Architecture, Structure and MEP.
nmarcelis
Also depending if the crash occurs with specific projects you can find help here:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
If the problem always occur when working with Revit:
But its 'normal' for revit to crash once in a while.
Could be any number of reasons.  You need to provide more information than that for us to help you troubleshoot.  If it's inexplicable, then read your journal file.  Maybe you can track down the root cause that way.
