Room computations only succeeded without considering the following elements.
Message 1 of 9
Whenever I place or delete walls this error message pops up.
Please see the attached video!
Thanks!
Replies (8)
Message 2 of 9
The error message isn't showing in the video, but its there. It reads just as the title says.
Message 3 of 9
nmarcelis
Do you have linked files in this project?
Ifso:
This can happen if there are thin room bounding elements in the linked files which sit on top of the reference level.
If this is the case, there are a couple ways to get around this,
A) make sure those elements are not room bounding, or
B) raise the computation height above those elements.
For more information about Computation Hieght, please review the following page:
About Computation Height for Rooms
Revit Certified Professional Architecture, Structure and MEP.
Message 4 of 9
I have a Revit family that I brought into the project. Could that be it?
How would I  " make sure those elements are not room bounding" in my project?
Message 5 of 9
nmarcelis
Could you first expand the warning so we can now what type of elements are causing the warning?
Message 6 of 9
See attached.
Message 7 of 9
nmarcelis
Can you click on show to visualize the elements?
Message 8 of 9
See attached.
Message 9 of 9
Deleting that wall solved this issue! Thanks!
