A generation bug of the Generative Design tool?
Everything was fine when I ran the Generative Design tool for my first several times. Official examples and one of my own sample to calculate volumes worked well.
However, after I create another sample, the Generative Design began to choose only one condition to calculate all the possible solutions. Even when I calculate the official samples, I got the same incorrect solutions. Was I wrong, or there was some bugs in the tool?
Here are some screenshots about this problem.
Lance.Coffey
Autodesk Support
Autodesk Support
Thank you for the question @Anonymous!
If you haven’t already done so, I would suggest ensuring that Generative Design is updated to the latest version (21.6.0). You can check the version on the Programs and Features Control Panel or in the Windows Settings dialog.
Updates can be loaded through the Desktop App, or through your Autodesk Manage page.
If you see the same behavior with the latest update, could you reply with the settings you are specifying for the study (so that we can try reproducing your results)?
Lance Coffey
Technical Support Specialist
