hello , i have get this problem after update revit 2019 the plugins is not working at all magicad, vray, twinmotion link, lumion live sync every addons i was installing in revit know is not working i try to uninstall and reinstall the plugins put it didn't work what can i do to make it work?
Gelöst! Gehe zur Lösung
Gelöst von Lance.Coffey. Gehe zur Lösung
Hello @nawafa8, welcome to the Autodesk forum!
The latest update for Revit 2019 is 2019.2.2. If you recently install 2019.2, then I would suggest installing the latest update of 2019.2.2 and retesting the add-ins.
If this issue is occurring with the 2019.2.2 version, then it sounds like either something went wrong with all of the add-ins (at the same time) or there is a problem with the Revit installation.
On the Revit side of this issue, I would suggest trying the following:
On the add-ins side of this issue, I would suggest contacting the maker of the add-in(s) for troubleshooting.
