A CRITICAL PROBLEM WHEN I EXPORT FROM RIVET TO CAD
Mohamed_Faramawy
Message 1 of 9
Mohamed_Faramawy
When i export from rivet to cad, i get some critical problem i hope someone can help me:
1. when i join walls with columns rivet exports the columns exploded
2. the wall has several layers in it's (structure - substance - finish) and when i export all these lines get the A-WALL layer in cad, and i can't assign (A-WALL) layer only to the wall core 3. the A-WALL never surrounds the column as it should be presented I attached the rivet file , and a simple cad file with the relationship between col. and wall that i wish to reach finally
Replies (8)
Message 2 of 9
I don't have time today to look at your file that closely but you must make the Revit look how you want it to look before exporting to CAD.  The screenshots below shows a couple of the conditions in your Revit file.  They are quite funky IMHO so please make sure that is how you want them to look.  If you can't make it yourself, draw a drafting detail with proper line weights assigned so that we can understand your intent.
As for exporting to AutoCAD, I personally don't use that to a great extent so I cannot project my opinion too far.  But I will take a look when I have time later today or tomorrow.
Last but not least, if you need to ATTN your topic directly to me, use tag @ToanDN in the post itself, but do not send PM.  I will not answer question via PM.  It is for buddy chit-chatting, backstabbing and that kind of stuff (just kidding lol).
Message 3 of 9
Sorry, but it is very, very difficult to understand what you are saying in both of your posts about your issue. I tested a rvt-to-dwg export using the file you uploaded and I had no issues on my end.  What, precisely, are the issues you are having on your end? If possible, please provide a coherent workflow to replicate.
Message 4 of 9
Mohamed_Faramawy
First of all I'd like to thank you for your time and respond
2nd. Sorry for sending a p.m but I'm still not familiar with the site standards and it was a critical and urgent problem which i didn't find a solution till now
Message 5 of 9
Mohamed_Faramawy
@Anonymous
Dear friend, the problem is simply that. I attached here a cad file shows the relationship required between a column and a wall I mean the graphics relationship.
Now if u can export from the revit file i attached also the same relationship please do thar and post me rhe revit file
Message 6 of 9
Anyways, here's the ACAD file for your inspection. "Relationships" look fine to me, but then again, I don't understand what I'm looking for specifically.
Message 7 of 9
Mohamed_Faramawy
Okay first of all please export the living room floor because in this level you can see the relationship between the columns and the wall but in the floor you exported this problem is not appearing.
Anyway I will try to explain my problem in our standards in the office we need the the wall structure line to be continuous overlapping the column if the column is intersecting the wall as shown in the AutoCAD file I am attaching if you can see the wall has yellow thick line and it is overlapping the column these walls has an offset grey color Thin Line indicates the finishing now I cannot exported from the Revit to get the same results if you can please help me do adjusted export setup to give this result I highly recommend that you download the CAD file and take a look so that you can understand me better and thanks a lot for your time and your response
Message 8 of 9
Look at the CAD file see if it is close to what you want.  If so, look at the Revit file at that particular column location and see what changed.
Message 9 of 9
Mohamed_Faramawy
Thanks for ur effort but the result isn't matching the required from neither close nor far.
Please, again take a look to the cad file i am attaching, i attached it again here in this reply
thanks once again to ur time and effort, but i begun to believe that revit can't export drawing to CAD like the way we wish
