Detail lines Printing and Section Line Shape
2 ANTWORTEN 2
Nachricht 1 von 3
Ahmad-Ramadan
1056 Aufrufe, 2 Antworten
1- Detail lines appear in printing (Pdf and on Paper) like what i mentioned in the attached photo it shows my line and another dashed black line i didnt draw!! and
- also appear like that when i export it to autocad but in autocad i have to hide A-DETL-HDLN Layer to hide it is it right or it will hide another things! i dont know
2- Section Line i tried to make it continues but i couldnt.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Ahmad-Ramadan
For detail lines in point 1, could you post the RVT file or a screen capture to show what you see in the view.
Section line looks like the section head markers have been created as custom, the section line normally radiates from the end of the 'arrow/direction' mark this could be the 'gap' you see when customising the head the extents are not matching the default gap allowance. It look to me that the section 'line' is continuous. when the section heads are places with a greater distance between them does the 'line' extend with the same 'gap'?
Nachricht 3 von 3
Ahmad-Ramadan
als Antwort auf: Anonymous
thanks Lura :leicht_lächelndes_Gesicht:  for your reply
first point - the lines appear like what id did on Screen but on paper or any export it show like what i tell before :enttäuschtes_Gesicht:
Second - the section always drawn like this i always have this gap between the section heads an it's line i dont know why! could you attach your revit Section family to try!
thanks again :leicht_lächelndes_Gesicht:
