700+ MB file IFC Export
faijanuddinshaikh
faijanuddinshaikh
Hello, I'm trying to export a 700 MB revit file to IFC. I tried this with 2019 but it would crash right after trying to export the model and then I switched to Revit 2024 to export it but this version just gets stuck at "not responding". What am I supposed to do now? How can I export this revit file to IFC without using any paid software?
While I was writing this post, revit 2024 crashed as well....phew...
Any help would be greatly appreciated. Thank you.
faijanuddinshaikh
My PC specs are i5-12500 and 16GB of RAM.
ralphdenhaan
Can you first open the file with Audit? and then try to export the file to IFC?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
faijanuddinshaikh
I will try that and give an update. Another thing I want to add is that the Revit file has some imported elements (generic models) from tekla. Let's hope that's not messing up the export?
faijanuddinshaikh
I tried exporting just the link file (Tekla revit link file) and it seems that's the issue. It's getting stuck during exporting.
