Good morning, when exporting a Revit 2024 plan to DWG, some elements change their location. However, there are no problems printing the plans to PDF or directly from Revit to paper. That same file in version 2022 does not cause problems in its export.
The upper image is in 2022 and the lower one is in 2024 in which you can see the elements it moves
is the content that shifted from a link?
Howard Munsell
I have looked and everything is correct. What's more, when I print on paper or PDF everything is correct. If I print the old file from the 2022 version, the dwg does not cause problems. The 2024 version file is updated from 2022. It is practically the same except for some walls
I assume it is a link then
, and the coordinates are the same in both models and Shared Coordinates were used, and they linked perfectly the first time?
When you export to DWG, in the Units & Coordinates tab, are you selecting Shared or Internal?
Howard Munsell
I have tried it with all the drive options and selecting Shared and Internal. But it does the same
have you try this ?
would you be able to upload the models(s) for us to look at? if the files are too large, etransmit them and strip out all the views and sheets. it might make it small enough :-).
Howard Munsell
