Hi there,
I want to use 60 degree parking spaces for my work, but they aren't there in the drop down menu after selecting massing on site>parking component. Even when I go to load family in the parking folder there is nothing. All there is the standard 90 degree parking spaces. All the videos I am watching has 90 degree, 70 degree, 60 degree etc in the properties drop down menu, but I don't. Could somebody help please?
Parking families are not system families, it means that you need to create the family you need, like you do to Windows and doors...
You can use the standard Parking family and edit the orientation of the array like the one attached.
Hope it helps
have you seen my file attached?
Try to open it, is very simple you just need to place the second parking spot in the position you want it to be with the first parking spot and it will create the array. then import in your revit file.
If my answer helped you please accept it as solution.
You're in the wrong location. Go here:
C:\ProgramData\Autodesk\RVT 2020\Libraries\US Imperial\Site\Parking\Parking Space.rfa
Metric:
C:\ProgramData\Autodesk\RVT 2020\Libraries\US Metric\Site\Parking\M_Parking Symbol - ADA.rfa
The FAMILY TYPES dialog box is in the Family. Open the Family to access it.
...see attachment
