cannot find imported dwg in title block family
6 ANTWORTEN 6
Nachricht 1 von 7
mairh_tsek
705 Aufrufe, 6 Antworten
Hello all,
I imported a dwg file in a Titleblock family in order to have it as a reference. The scale of the dwg was really big (because of the units) so I imported it again with the correct units and it was ok.
The problem is that when I import the titleblock in the Revit project, it is really small because it seems that the dwg with the wrong scale is always inside the family. When I check the family,  there is not any imported file (I had deleted the dwgs ) , I have checked all the visibility parameters. Check images.
Do you have any idea?
Thank you in advance!
6 ANTWORTEN 6
Nachricht 2 von 7
hmunsell
als Antwort auf: mairh_tsek
fix the units in the DWG so it imports correctly from the start.
Howard Munsell
Nachricht 3 von 7
mairh_tsek
als Antwort auf: hmunsell
Yes I fixed them, and the second importation was correct.  but the first dwg with the wrong scale seems to be still in the rfa and I cannot find a way to delete it.
Nachricht 4 von 7
hmunsell
Ahhhh i see...
Did you go to Mange > Purge Unused ?
also if you imported the DWG you brought in a  the layers, line styles, hatch patterns, etc.... they should be cleaned out and a Purge will not get them. Manage > Additional Settings > Fill Patters, Line Styles, Line Patterns and clean out all the stuff that came in from the CAD import.
Howard Munsell
Nachricht 5 von 7
mairh_tsek
Yes I did it. It is so strange.. I checked everything inside the family and I cannot find it.  Just one more info that maybe help.. in the project I see this dwg when I go V/G and turn on Imported categories > Imports in families
If I run Dynamo it seems that there is in the .rfa the imported dwg (I suppose that it is) but I cannot delete it. (maybe it is pinned?!)
Thank you!
Nachricht 6 von 7
hmunsell
try pyRevit it is a free tool for revit. i believe there are tools in there to help clean out that kind of content.
https://www.youtube.com/watch?v=-hIMH_dIUuw
Howard Munsell
Nachricht 7 von 7
hmunsell
also, can you attach the .rfa file for us to look at?
Howard Munsell
