3DS Max to Revit Workflow - IFC import issues
gus.a
gus.a
Here is the workflow I go through to get 3DS Max objects in to Revit.
Workflow
3DS Max  Select Edit Poly Objects > Export Selected to DWG
AutoCAD Open File > Export to IFC
Revit Open > IFC
Issue
Some objects don't show up when opening the file IFC file in Revit. I exported the missing objects by themselves and brought them into Revit and I get the following error message.
The following problems were encountered in the IFC file: No building elements were found in the file
Please let me know what I can do to get these models into Revit or if you have a better workflow in getting 3DS Max Objects into Revit.
Thanks!
Can you import DWG directly to Revit? Do you need to manipulate the form in Revit?
gus.a
I want to be able to move the objects around and section through them. For some reason when I import DWG files sectioning through the objects doesnt work very well.
I found out that the IFC exported from AutoCAD is the one causing the issue. Here is the log for the exported IFC file.
 [DefaultDomain:     ]EXPORT STARTED: 8/26/2016 10:21:00 AM
 [DefaultDomain:     ]
 Object Count:
 - AcDbSubDMesh : Total:  (61) Fail:  (32)
   ** = Object classified as other IFC object.
 [DefaultDomain:     ]EXPORT ENDED: 8/26/2016 10:21:09 AM
Lance.Coffey
Autodesk Support
Autodesk Support
If you load the DWG into a family (either loadable or in-place) I believe you should then be able to section the DWG geometry.
Can you verify if this works for you?
Lance Coffey
Technical Support Specialist
