3DS Max to Revit Workflow - IFC import issues
- Mute
- Permalink
- Report
Here is the workflow I go through to get 3DS Max objects in to Revit.
Workflow
3DS Max Select Edit Poly Objects > Export Selected to DWG
AutoCAD Open File > Export to IFC
Revit Open > IFC
Issue
Some objects don't show up when opening the file IFC file in Revit. I exported the missing objects by themselves and brought them into Revit and I get the following error message.
| The following problems were encountered in the IFC file: No building elements were found in the file |
Please let me know what I can do to get these models into Revit or if you have a better workflow in getting 3DS Max Objects into Revit.
Thanks!
