3D wrong after doing an interference check
Ramina_B
Message 1 of 13
Ramina_B
After I tried to do an interference check, all my 3D views are now showing as wireline.
If I try to make a new 3D view, nothing shows up, the same with my site plan.
Is there a way to ''close'' the interference check?
Replies (12)
Message 2 of 13
This a oddity I haven't heard about or seen before.  All your 3Ds are actually stuck in wireframe?   How did you "try" to do an interference check?  Is it a 3rd party app or Revit's?
Message 3 of 13
Ramina_B
I clicked on Collaborate -> Inteference Check -> Selected some catergories.
That made my Revit view go wireframe.
And the views are also stuck, I can't select anything in that format.
Message 4 of 13
Try and duplicate the view to check if the issue persists - it would seem like a graphics issue.  Perhaps try to uncheck Use hardware acceleration.
Message 5 of 13
What are you comparing?
Message 6 of 13
Kimtaurus
The views are corrupt, we've had the same happening in our office (mainly on larger projects).
Delete the view and recreate.
If there's any V/G overrides save them first in a template.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Message 7 of 13
Ramina_B
When I recreate a 3D view, same thing happens. I only have 1 view that don't have the issue.
I can't seem to get around it.
Message 8 of 13
Kimtaurus
Are you starting from scratch or copying a view?
Message 9 of 13
RobDraw
Have you restarted your computer and/or Revit?
Rob
Message 10 of 13
Ramina_B
Starting from scratch, in the same project ofc.
Message 11 of 13
Ramina_B
It's been going on for 5-7 days now.
Message 12 of 13
RobDraw
You didn't answer the question.
Rob
Message 13 of 13
Ramina_B
Yes, I've been restarting every day.
