3D Wall Types
2 REPLIES 2
PhilvK
345 Views, 2 Replies
3D Wall Types
Does anyone create these type of details regularly using Revit? I’m think of using this style for wall types, and by using parts and moving the layers back and forth in the different wall styles, it seems you can quickly get a nice 3D representation of a wall. My questions is, if the wall core was metal studs in the example below, wouldn’t you have to create the studs as a model or detail line like I sketched in red, correct? The other way to ask the question is: if you want this type of detailing, isn’t it quicker and easier to do it in SketchUp?
2 REPLIES 2
in reply to: PhilvK
If you must have this kind of presentation, what prevents you from modeling the metal framing using extrusion or sweep or whatever? While you could do it with parts and wall layers, I would created a generic model family so that it can be reused among projects more easily. You can certainly do it in SketchUp and bring the rendering in as well. It is hard to tell wich way is quicker because it totally depends on you skills at each piece of software.
With that being said, I can't find myself doing this unless it is required for understanding constructability of a very complex intersection. But it is just me.
bms953
in reply to: PhilvK
take a look to this page you can do this very fast : https://dddmodeling.wordpress.com/2016/07/10/how-we-can-create-good-presentation-in-revit-for-wall-f...
Behzad Meskini
Competitor in World skills Competition 2005 Finland (Mech,Eng,CADD)
Member of Iranian Elite Foundation
Autodesk Certified Professional-AutoCAD
Autodesk Certified Professional-Inventor Pro
Autodesk Certified Professional-3ds Max
Autodesk Certified Professional-Revit Architecture
Autodesk Certified Professional-Revit Structure
Autodesk Certified Professional-Revit MEP
DS CATIA Certified V5 Mechanical Surface Designer Specialist
DS CATIA Certified V5 Associate - Part Design
DS CATIA Certified V5 Associate - Surface Design
DS Solidworks-CSWP-Mechanical Design Professional
DS Solidworks-CSWA-Advanced Sheet Metal Professional
DS Solidworks-CSWA-Advanced Weldments Professional
DS Solidworks-CSWA-Advanced Surface Professional
DS Solidworks-CSWA-Advanced Drawing Professional
Forma Design Contest
Technology Administrators
