3D Views
3D Views
dsalvagni
Message 1 of 17
3D Views
dsalvagni
Is there a way to halftone existing items in a 3d View, but not new items?
Replies (16)
Message 2 of 17
Tom_Kunsman
Do you have any Graphic Overrides set up in your Phasing options? If not (I would set some up), you could try using a filter. You'd need a filter for nearly every category, which is why the graphic overrides might be better
Message 3 of 17
dsalvagni
I do have graphis overrides set up under phasing but that seems to only affect plans/elevations/sections
[cid:ca0ee460-4cdc-4543-b60a-47626e9388c0]
Message 4 of 17
vitorbortoncello
yes, with phase filters. For 3D views, use shading or consistent colors to display graphics
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 5 of 17
Phase Filters Exist for all Views.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-DB104358-4D5A-494E-ACAE-BB8B4E72E572
Perhaps the 3D View is corrupt. It happens. If it is the default {3D}, delete it and create a new one by pressing the lil' house icon on the QAT.
Message 6 of 17
dsalvagni
my phase filter is set to Phase Filter Previous and New and Phase New Construction and it displays like this, the all gray section should be a halftone
[cid:c483d1f1-4302-4afd-af4f-3791c957ec55]
Message 7 of 17
dsalvagni
Im not following you, this is what my 3D view looks like, the gray section on the left is the existing building that I want to put a halftone on.
[cid:4e5c3dc2-0170-4e66-9c64-f95158454740]
Message 8 of 17
Have you ruled out the possibility that is it a corrupted view?
BTW: no screenshots of yours are being posted.  This is all I see at my end: [cid:c483d1f1-4302-4afd-af4f-3791c957ec55]
Message 9 of 17
vitorbortoncello
Refer to Tom Kunsman's post. Ensure the 'Halftone' option is checked in the graphic display settings for existing elements.
To make sure it displays correctly, your elements must be phased as existing in the properties tab and the phase in phase filters must be overriden:
Also, if none of that works, and it is not corrupted view, check for possible overrides:
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-67D3D6DB-E78D-4711-B9C3-4D30F1C22205
Message 10 of 17
dsalvagni
yes i created a new view and got the same result.
Message 11 of 17
azad.Nanva
i don't see your views(screenshots),but the question is :
do you means the phases right?so you can adjust the overrides material and etc.like small movie below and in phase filters you should adjust the existing on Overridden to show  halftone or transparant.
Message 12 of 17
dsalvagni
They are because the plan displays the existing items as a halftone, just not the 3d view
Message 13 of 17
dsalvagni
it is checked in the phase filters
Message 14 of 17
SteveKStafford
Is there a linked model too? Phase Filters between models must match exactly by name or the graphics overrides won't work on the linked model elements.
Fwiw, the Phase Filter Show Complete is intended to be set to By Category for both New and Exist phase status columns because that filter is meant to show both phases "as complete"...without a difference between them. When you changed the column to Overridden the elements that you changed to existing looked different because of the graphics overrides you've applied. To show a contrast between existing and new the phase filter, Show Previous and New should be used and the New status should be By Category and Existing status should be Overridden.
What does the project's Halftone/Underlay dialog show?
Manage ribbon > Additional Settings > Halftone/Underlay
Steve Stafford
Message 15 of 17
dsalvagni
There is no linked revit files, I am working in design options.  It shows correctly in plan and elevations and sections, just not in a 3d view.
this is my 3d View.  the gray section is the existing, I want that to be halftoned.
Message 16 of 17
SteveKStafford
I think that it is just more subtle in the 3D view than in plan views. If you change between the Graphic Settings of the view, hidden line etc. You'll find switching between halftone in the phase graphic overrides is noticeable, just more subtle difference than in plan views.
Steve Stafford
Message 17 of 17
