3d views disappearing when I rotate
Hi.  When I am viewing in 3D and I try to rotate my view, my house disappears, it doesn't matter how slight I rotate.  Also, my tool boxes on the side won't snap to the side.  HELP!
anis.123
Try to click on any element of house eg. wall, and then rotate!!!! Sometimes this may resolve the problem
Do you have anything very far from the house? What if you select an element of the house and orbit, does it rotate around the selected element? What if you delete the 3d view and create a new one? What if you disable hardware acceleration?
PijPiwo
3D view easily can get corrupted. Delete it and click on 3D icon in QAT to create a new one.
Tool boxes? Are you referring to Properties and Project Browser windows? See this.
Oh man that worked! Thank you so much!
That worked thank you!
this doesn't work with me, even the sample projects are not visible in Revit. I tried Revit 2020 and 2019, and my laptop is brand new with very good hardware, what should I do?
