3D View showing as semi - Transparent
jdivina2ZDQ5
6,600件の閲覧回数
10件の返信
メッセージ1/11
jdivina2ZDQ5
HI all, I have looked at all the solutions that have been posted and none of them have worked.
Tried:
- recreating the 3D view by deleting it and creating a new one.
- changed target and eye elevation
- zoom to fit
-no cad to delete.
- deleted the only linked file within the file.
-audited the file.
-visibility settings show no transparancy
- no view template
Any one have any more solutions I could try as none were working.
0 件のいいね
解決済み
6,601件の閲覧回数
10件の返信
返信 (10)
メッセージ2/11
RDAOU
@jdivina2ZDQ5
To narrow down the guessing...check also the suggestions on the following forum posts
While at it check also Phase filter and Phase Overrides
Solved: transparent wall and floor - Autodesk Community - Revit Products
Solved: 3D Perspective View Graphics Issues - Transparent Geometry - Autodesk Community - Revit Prod...
Walls are transparent n 3D view - Revit Forum
0 件のいいね
メッセージ3/11
jdivina2ZDQ5
Thanks. I've tried every single one of those and they weren't the solution.
On all the other levels they still work. and views too. So not sure what it is now.
0 件のいいね
メッセージ4/11
RDAOU
@jdivina2ZDQ5
Can you share the model?
0 件のいいね
メッセージ5/11
jdivina2ZDQ5
I had to delete parts and purge it. So hopefully this helps. It was a large file as it came from an ifc file.
0 件のいいね
メッセージ6/11
RDAOU
@jdivina2ZDQ5  Can you relinquish all elements/worksets and save a detached model ...
0 件のいいね
メッセージ7/11
jdivina2ZDQ5
Oops sorry I totally forgot to do that when I was rushing to get it on here.
I'll attach,.
0 件のいいね
メッセージ8/11
解決済み
You have a bunch of materials that are transparent / semi-transparent.  After changing some to opaque.
0 件のいいね
メッセージ9/11
jdivina2ZDQ5
Well ****., I think that's it. The only thing I didn't try. Because we exported the IFC from another software and opened it in Revit.
We didn't change anything within the software's settings or in Revit. All the other times we did it, it worked fine.
0 件のいいね
メッセージ10/11
RDAOU
@jdivina2ZDQ5
I thought you did check all the solution in the above sites! You have a CustomeTextTexture which is transparent. Setting it to Render appearance or Removing transparency resolves the issue
0 件のいいね
メッセージ11/11
jdivina2ZDQ5
Thank you DR.RD and ToanDN
I appreciate the help. This has made my life easier.
0 件のいいね
