- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
This is my first post, I've been working with Revit since January of this year from zero (First time using the software). And I have created an architectural model which later on, I linked it to a MEP Project I was working on.
I have been having problems with the 3D View in a Realistic Visual Style from the beginning. The first issue was All the elements from the architectural link were colorless or transparent. I did some researches and I found that the problem was the Discipline of the view (It was Plumbing), changing it to "Coordination" solved the problem. But from some days ago, around 2 weeks ago, I am struggling with a new problem which till today I couldn't find a solution by myself or any post in the forum. The problem is sometimes when I set up a "Realistic with edges" visual style, ALL (Architectural link and MEP elements) elements disappear but they can be selectable. If I press and hold the mouse wheel to orbit, all the elements appear and even if I orbit, the model shows. Once I stop holding the mouse wheel, everything disappear. Something interesting is when I change of Visual Style, the 3D View works.
On the other hand, I would like to say my pc was upgraded and before this problem, the 3D view was working perfectly without any problem in all they visual styles. In fact, yesterday I created a walkthrough and I exported it with the visual style as Realistic with edges.
Also, I attached two screenshots, the first one shows the issue that I have, and the other one show how suppose it has to be.
Thanks for any reply, hope you can help me.
