3D software that is compatible with Revit?
Message 1 of 14
I have Revit LT am in need of placing 3D files into the program.
I am currently making 3D drawings, then turning them into a dwg file in AutoCAD LT but it is not correctly transferring my 3D files into Revit.
Will I need to upgrade to AutoCAD in order to get a 3D file placed into Revit?
Replies (13)
Message 2 of 14
DarrenP
with Autocad LT you can't create 3d models so don't know what your trying to accomplish
DarrenP
Message 3 of 14
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk Community! I see that you are visiting as a new member Smiley Happy
Did you try linking the CAD file in Revit? which version of AutoCAD and Revit are you using?
If you are using Revit 2017 or earlier and trying to link an AutoCAD 2018 .dwg, you receive errors and it does not link.
Let me know if you have additional questions.
Message 4 of 14
What program would you recommend to create for 3D files going into Revit?
Message 5 of 14
loboarch
Why not just create whatever 3d geometry you need in Revit?
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 6 of 14
Viveka_CD
Hi @Anonymous
What 3D model are you trying to create? If you can share an image it will be helpful.
Message 7 of 14
My team that is making the designs are more familiar and trained in AutoCAD.
Message 8 of 14
Can I use AutoCAD?
Message 9 of 14
aRcHiTeCt.JM
 what you need is to learn REVIT
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 10 of 14
Yes of course there is a lot I need to learn. I wanted a quick answer before I dive too deep to see if it is even possible to link a 3D file, or ACIS object into Revit LT or if I need to upgrade to Revit.
Message 11 of 14
Alfredo_Medina
@Anonymous Then, why don't you continue in AutoCAD? Or is there any requirement for your current project to be in Revit?
Message 12 of 14
If the design is in Autocad, keep everything in Autocad.  If the design is calling for it to be in Revit, then it has to be done in Revit, not imported from Autocad into Revit.  The ability to bring in Autocad drawings are more for reference value only.
If your company is more familiar with Autocad, then I would suggest going to Autocad Architecture before going to Revit.
Message 13 of 14
Viveka_CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Let us know if you have additional questions and if any of the posts helped.
Please mark any posts that help with "Accept as Solution" and thanks!
Message 14 of 14
Yes I gather that I need to upgrade to Revit in order to get access to my .sat files.
