3D REALISTIC MODE DOESN'T SHOW ANYTHING (TRANSPARENT)
Message 1 of 8
Hi guys,
I'm having an issue for a couple of days.
My Revit project does not show anything (not even walls, ceiling, families, nothing) when I change for  3D REALISTIC MODE. It just shows when I scroll up and down, and only black lines and figures.  In the other graphic displays (hidden line, shaded, etc) it works normally. It is not related to eye or target elevation, I've tried it.
I searched on internet solutions but nothing worked.
CAN ANYONE HELP ME?
Thank you
Replies (7)
Message 2 of 8
You too?  2022?  The Realistic View looks like a Wireframe View? No Materials?
Message 3 of 8
mauricio_mssf
try to delete the 3d view and make another one.
there was a similar error that could be solved in this way.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 4 of 8
onur_duran
I had the same problem too! When I open my project by double clicking it, it wouldn't show me anything while using realistic view unless I pan to look around! But when I open my project with open button on main window in revit, it works and navigate normally! I couldn't get it work no matter what I tried, even formatting! So I installed 2021 back again and will wait for 2022 gets an update! I uploaded screen recordings for you to see!
PS: I have an RTX2080 with 32gb Ram. Tried disabling hardware acceleration, updated drivers, format etc.
Message 5 of 8
2022 Realistic without Shadows vs. Realistic with Shadows:
Message 6 of 8
cris.bru99arq
Thanks a lot @mauricio_mssf ! I had this problem and I solved it by deleting and recreating the 3d view.
accepted solution
Message 7 of 8
lorissa
I am having this problem too.  Deleting the 3d file and turning shadows off didn't help.  The model shows when I pan, but otherwise just dissapears.  Shows up in wireframe and hidden view, but not in realistic.  Works fine in Camera view.
Message 8 of 8
gokil.raja
You there is a 3D cube in 3D view. once these kind of visual error comes into display click on down arrow near 3D cube and change to orthographic view and click home icon on top of 3D cube. This will clearly solve any graphical issue, instead of deleting a entire view. This can be prefered instead of deleting a 3D view. Only very few revit version have this issues on 3D views
