3d perspective camera
6 REPLIES 6
2841 Views, 6 Replies
I am having issues with creating perceptive views when using the camera tool.
I believe the problem is that the camera is set to produce two-point perspective views
I want to produce single point perspective (true perspective) but i can not find how this setting is changed if possible at all.
6 REPLIES 6
Is the one below 1-point or 2-point perspective?
in reply to: ToanDN
I am not sure.. but this is the type of 3d view id like to generate!
1-point or 2-point perspective pertain to the objects themselves.  Say if a box placed parallel to the camera plane then it only has 1 focal point aka 1-point perspective.  If the box is not parallel to the camera plane then it has 2 focal points aka 2-point perspective.  You can totally have 1-point and 2-point objects in a single view.
So how you place the camera and the target point is critical.  See the example, the camera plane has to perfectly parallel with the front walls.
in reply to: ToanDN
Ok so I am placing my camera as shown in the first picture
the second picture is the 3d view generated
then going back to the plan to see the camera 'extents' and it is super wide, not what i set it to begin with
I am wondering how i can edit this 'width'
an example of what i see in an identical mdoel done in sketch up versus in revit.
I do not want to have to work in both models
