3D PDF Export
4 REPLIES 4
brandon.chetram
227 Views, 4 Replies
3D PDF Export
brandon.chetram
I am currently trying to export my model to a 3D PDF, but the exported PDF does not keep the same color properties as the Revit file. Is there a way to carry the colors to the 3D PDF?
3D PDF Export
4 REPLIES 4
MKJOR
in reply to: brandon.chetram
MKJOR
MKJOR
MKJOR
You can also export as Image then Convert to PDF by using 3rd Party website or even you can print the exported image as PDF.
RDAOU
RDAOU
@brandon.chetram
Can you post them side by side for comparison? The view you are exporting as a 3D and that which is in PDF
Otherwise, check the 3D PDF exporter settings!!
@brandon.chetram
brandon.chetram
in reply to: RDAOU
brandon.chetram
Here is the regular PDF export colors (the correct colors)
And here are the 3D pdf export colors:
