3d Logo
3d Logo
dcarlsen8GY35
Message 1 of 8
3d Logo
dcarlsen8GY35
Let's say I want to produce a 3d wall mountable logo - say the golden arches.... the equivalent of model text --- only a free form drawn profile and not a canned letter ?
Replies (7)
Message 2 of 8
Avaris.
I recommend this way: illustrator > explode into outline > export to dwg > load dwg in Revit > generic model extrusion with pick lines
Message 3 of 8
dcarlsen8GY35
thanks i don't have illustrator - what's the magic wand solution Smiley Happy
Message 4 of 8
Corsten.Au
Hi
Import Image in CAD..
Trace it..
Use that in Revit to Extrude..
In revit - you can use direct Raster Image if you just want to show images on wall
or any surface... restriction is, its only visible in Realistic or Render mode..
Best luck
Corsten
Building Designer
Message 5 of 8
dcarlsen8GY35
thanks....sounds like 2 solutions depending on your resources
Message 6 of 8
AzWoodWarrior
Use Autodesk Maya. You can make anything.
Message 7 of 8
dcarlsen8GY35
good if it will make a valid paid in full receipt for the 3495 i'm in
Message 8 of 8
AzWoodWarrior
30 day trial.
